Part is angle iron from CC so it has a rounded edge to it. Selected chamfer tool and Edge Chain of Single Edge. Chamfered edge is 35*45 degrees. But in the IDW when I use the Annotate/Chamfer option I can only select part of the chamfered edge line and the result is not the same as in the model. See below captures. Any ideas? I know I could use a cut extrude on the model, or just dimension the chamfer in the IDW but that's what the Chamfer tool is for isn't it?
Thank you very much to report this issue to us, which has been tracked as 1313884 in our database.
It seems that the drawing recomputer chamfer value in drawing side base on what edges we selected in drawing, please see attached image for the correct result.
