Inventor Forum
IDW CHAMFER DETAIL NOT SAME AS CHAMFERED EDGE OF CC COMPONENT
1 REPLY 1
brendan.henderson
1720 Views, 1 Reply
Part is angle iron from CC so it has a rounded edge to it. Selected chamfer tool and Edge Chain of Single Edge. Chamfered edge is 35*45 degrees. But in the IDW when I use the Annotate/Chamfer option I can only select part of the chamfered edge line and the result is not the same as in the model. See below captures. Any ideas? I know I could use a cut extrude on the model, or just dimension the chamfer in the IDW but that's what the Chamfer tool is for isn't it?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
1 REPLY 1
Thank you very much to report this issue to us, which has been tracked as 1313884 in our database.
It seems that the drawing recomputer chamfer value in drawing side base on what edges we selected in drawing, please see attached image for the correct result.
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
