Inventor Forum
iAssembly initial save for each member
13 REPLIES 13
Message 1 of 14
mikko.m
1295 Views, 13 Replies
mikko.m
I have an Iassembly with iPart as children . After modifying iParts table and generating it's members it prompts to make initial save for each member in iAssembly. Is there workaround for this?
_____________________________________________________________________________________
Inventor Professional 2019.3
Vault Workgroup 2019.1.1
13 REPLIES 13
Message 2 of 14
Mark.Lancaster
in reply to: mikko.m
Mark.Lancaster
@mikko.m
Are you generating the members of the iAssembly?  If you just made changes to the iAssembly table it shouldn't be prompting you to save each member of the table.
Can you show us your workflow (using Autodesk Screencast: https://knowledge.autodesk.com/community/screencast).
Mark Lancaster
@mikko.m
Mark Lancaster
Message 3 of 14
mikko.m
in reply to: Mark.Lancaster
mikko.m
Not yet, it prompted this initial save window first after opening iAssembly. Changes were made to iPart table.
Message 4 of 14
mikko.m
mikko.m
I tried to replicate error with sample files but those worked fine.
Assembly structure
+iAssembly1
    ->iAssembly2
    ->Part.ipt
             +iAssembly2
                    ->iPart
                    ->part2.ipt
iAssembly and ipart contains dozens of members. I have to test more and get back.
Assembly structure
+iAssembly1
    ->iAssembly2
    ->Part.ipt
             +iAssembly2
                    ->iPart
                    ->part2.ipt
Message 5 of 14
johnsonshiue
johnsonshiue
Hi! I believe these member files did not exist on disk before you make changes to the iPart and iAssembly right? The recommended workflow is to generate the iPart members by selecting member nodes in the browser -> Generate files.
Many thanks!
Software Test Engineer
Many thanks!
Message 6 of 14
mikko.m
in reply to: johnsonshiue
mikko.m
@johnsonshiue
I was able to reproduce the problem. I added workplane columns to iParts table. initial_save1.JPG
Then generated all the members and saved the file. Opened the iAssembly containing the iPart and then generated iAssembly members. Then it prompts this window for each member (initial save). In this folder I can see the old files getting deleted and replaced by the new ones.
@johnsonshiue
Tags (1)
Message 7 of 14
mikko.m
mikko.m
Sample files attached.
Message 8 of 14
johnsonshiue
johnsonshiue
Hi! If I understood how iAssembly works correctly, this is actually how iAssembly works. When there is any change in iAssembly factory prompting iAssembly member to update, the existing member will be deleted from disc and a new version of the member files will be created.
Many thanks!
Many thanks!
Message 9 of 14
mikko.m
mikko.m
Ok but then there has to be way not to prompt this for each member. It's very slow to click OK for 100 times.
Message 10 of 14
johnsonshiue
johnsonshiue
Hi! Unfortunately, I am not aware of a workflow to suppress the Save dialog for each iAssembly member save. Some users create another assembly like a container. Then place all the members in this container assembly. When there is a need to update, all members will be updated and listed in the same Save dialog.
Many thanks!
Many thanks!
Message 11 of 14
mikko.m
mikko.m
Can members be placed directly from the folder that iPart/iAssembly creates?
Message 12 of 14
johnsonshiue
johnsonshiue
Yes! They are actually like any other Inventor file. The only difference is that they are totally driven by the iPart/iAssembly factory (except custom iPart members) and they have a link back to the factory file. Other than that, they behave like regular Inventor files.
Many thanks!
Many thanks!
Message 13 of 14
mikko.m
mikko.m
Ok, thanks.
Now there is idea to suppress the save dialog:
Option to suppress the Save dialog for each iAssembly member save
Ok, thanks.
Message 14 of 14
Paul1084
Paul1084
Hi all,
I think I have found a work around for this... Locate a heavy object, place said object on the enter key.... go and make a cup of tea... return to find all members generated! voila!
Hi all,
