IAM File change to Autodesk Inventor Assembly
zahariHE2PW
Message 1 of 16
zahariHE2PW
Please help me to troubleshoot this. Can't change to Autodesk Inventor Assembly. The IDW,IPN and IPT was ok. IAM only got problem.
Replies (15)
Message 2 of 16
CCarreiras
HI!
1-Create a file PROJECT to that folder (*.ipj) and activate it.
2-I would try to delete the original assembly file, and rename the copied one:
(create backups before deleting)
CCarreiras
Message 3 of 16
zahariHE2PW
Sorry. Its not work. Assembly file still logo inventor type IAM FIle.
I want to change the file logo inventor to assembly logo.
Message 4 of 16
CCarreiras
That is a Windows issue regarding the icon it use, thats not an Inventor issue.
You have to tell windows which icon it must use.
...This is important for you?!!
CCarreiras
Message 5 of 16
zahariHE2PW
So how to fix this ??
Yes very important . If using inventor standard icon , file will open by double click on file.
But if using Inventor yellow symbol, file will open by another program Inventor again.
Message 6 of 16
CCarreiras
The icon doesn't have nothing to do with it...
So... Your problem is, how to avoid to open new Inventor instance when double click an Inventor file...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Opening-inventor-f...
CCarreiras
Message 7 of 16
zahariHE2PW
Change the icon very important . If not you cannot use design assistant to iam file
Message 8 of 16
CCarreiras
Of course you can still use the Design assistant.
Design assistant will look to the extension file (iam, ipt, idw, etc), not for the icon.
The icon is only a visual way to recognizes better the type of file... you can use any icon you select, and that will not change anything in the programs. The programs will open the files based in the extension.
CCarreiras
Message 9 of 16
zahariHE2PW
No . Cannot do that . Pack & Go also cant do.
Message 10 of 16
CCarreiras
How many Inventor versions have you installed?
CCarreiras
Message 11 of 16
zahariHE2PW
Inventor 2024 only. I still don't know how to fix it . Maybe I need to uninstall then install again if no solution.
Message 12 of 16
CCarreiras
Well... you can do that, uninstall/Install Inventor will not take so much time.
But... you can also try to fix it with the Autodesk solutions:
I believe the Inventor need to be re-registered, you can do that with these methods:
How to Re-Regestring Inventor (autodesk.com)
How to re-register Inventor via Command Prompt (autodesk.com)
Bsically both sites have similar solutions, re-register Inventor and reset register keys.
CCarreiras
Message 13 of 16
johnsonshiue
Hi! You may want to reset IconCache.db on your machine. Close all apps and go to File Explorer. Go to "%userprofile%\AppData\Local" and rename IconCache.db to IconCache.old. Reboot the machine. Does it work now?
Many thanks!
Software Test Engineer
Message 14 of 16
zahariHE2PW
Sorry . Not work after rename and reboot. Still same IAM file with Inventir 'I' Logo
Message 15 of 16
johnsonshiue
Hi! Try right-clicking on an iam file -> Open With -> select Inventor and check "Always use this app to open iam file" option.
Many thanks!
Message 16 of 16
zahariHE2PW
Fix it.  Thank You !!
