i imported data from excel to table in inventor drawing. I have delinked the excel. Now i cannot edit the excel. if i want edit we to link the excel again. Is there any solution edit the table after the delink the excel?
After cut the link with excel file, you should be able to continue editing, it's just a "free" excel file.
Try to delete the file and edit it. you cannot. I need to send this document someone without excel file. without the excel file you cannot edit.
Attached the file for reference.
Thank you for the support
Hi! I see the issue now. You would like to keep the content of the general table intact but unassociate it with the Excel file since it is no longer available. Unfortunately, there isn't a workflow like that. You will need to delete the table and recreate it manually.
Many thanks!
