Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I want to delink the excel from the table and i need edit the table its possible?
branjithkumar
branjithkumar
i imported data from excel to table in inventor drawing. I have delinked the excel. Now i cannot edit the excel. if i want edit we to link the excel again. Is there any solution edit the table after the delink  the excel?
CCarreiras
After cut the link with excel file, you should be able to continue editing, it's just a "free" excel file.
CCarreiras
branjithkumar
Try to delete the file and edit it. you cannot. I need to send this document someone without excel file. without the excel file you cannot edit.
Attached the file for reference.
Thank you for the support
johnsonshiue
Hi! I see the issue now. You would like to keep the content of the general table intact but unassociate it with the Excel file since it is no longer available. Unfortunately, there isn't a workflow like that. You will need to delete the table and recreate it manually.
Many thanks!
Software Test Engineer
