Hi
I need some help. I am working on a bolt to my M1 Garand Rifle.
I am almost done, I only need one function left.
I am running out of ideas how to solwe my issue. I have tried for over one and a half month
I have a Solidworks file (se inclused picture) , that shows the function, but I don't know how I make that function in Autodesk Inventor.
I have tried to use Loop, Sweep, Extrude functions, but I can't solved it out.
I have also inclued my part I am working on and the Solid works file, so you can see what I mean.
I thank you very much for your help 🙂
It looks like you have already accomplished the task ( in Solidworks )
hard to understand what you are looking for .
i seems you want the 2 surfaces chamfered.
looks like you could get away with a sweep with a path?
Hi! I believe you need to use Solid Sweep. The cut is made with sweeping a solid tool (a simplified bolt) along a desirable path.
Many thanks!
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
