I'm so lost - Modifying a Surface Composite Model
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 3rd party surface composite model that I want to modify. I have spent the last hour or so looking for a straight answer on how to do this and if anything, I'm more confused than ever. Every solution I've read might as well be in a foreign language. I am completely lost and out of my element. I just don't understand how to modify this type of model in any way.
File attached. This is a radiator component. It is currently 102 inches wide. I need to modify it to be 96 inches wide. I want to cut 3 inches out of one side and the same on the other side in order to retain all existing ports. I've added the green extrusions myself to indicate where I want to cut and remove material. After chopping the model into 3 sections, I then want to put them back together to form the new 96-inch wide component.
Honestly, I am ready to give up. Rather than waste even more time trying to figure this out, I'm going to just re-model it from scratch out of proper solids. It'll take me several hours minimum, but at least I'll be moving forward instead of banging my head against the wall trying to figure this out.
If there's an easy way to do what I'm describing, then I haven't found it. Thanks for reading.
