I'm having problems with the tree of my assembly
c.mateus
Message 1 of 21
c.mateus
I can't see the parts that are inside this assembly, any suggestions
Replies (20)
Message 2 of 21
blandb
Can you show a larger view of the model browser? Is it an empty assembly? Did you happen to promote/Demote components into other sub-assemblies and these are just the constraints to origin features?
Autodesk Certified Professional
Message 3 of 21
c.mateus
Message 4 of 21
c.mateus
It is a complete assembly with all parts and subassemblies, but the main assembly does not show the parts.
Message 5 of 21
blandb
Can you scroll the model browser down and capture more?
Message 6 of 21
CCarreiras
@blandb ,I guess if he scroll, the problem will be solved... 😂
@c.mateus :
Select a part, right mouse button and select "Find in Browser"
This will show you where the part is in the browser.
CCarreiras
Message 7 of 21
c.mateus
It doesn't solve it, I'm going to demonstrate two products, the first one is right with the subassemblies and parts, the second one doesn't show it, I discovered this problem when I searched (Ctrl+F) a part that I know is in that assembly and it doesn't show.
Message 8 of 21
c.mateus
Some configuration of the assembly that was like this, but I don't know how to solve it.
Message 9 of 21
blandb
@CCarreiras of course it will lol.
Just curious to see if the constraints were above the parts, never know how people put assemblies together via drag and drop, promotion/demotion....I mean without the assembly, can only give suggestions.
Message 10 of 21
c.mateus
Message 11 of 21
c.mateus
I like to assemble as it is actually done in production, each part assembled separately, soldering, assembly...
then put it all together, as is really done.
I never play everything in one assembly.
Message 12 of 21
c.mateus
See here, the constraints end and the parts do not appear, I already enter another subassembly and there is nothing, just constraints.
Message 13 of 21
blandb
Right click on the assy in the model browser and choose open, what do you see?
Message 14 of 21
c.mateus
The color has changed, but it's the same assembly,
see by name 003-00205.
Message 15 of 21
CCarreiras
Mateus, estás a trabalhar localmente ou a partir de um server?
CCarreiras
Message 16 of 21
blandb
Alright, click on the button with 3 horizontal bars in the top right of the model browser, go to Display preferences. Do you have "show children only" checked? If so, uncheck it. I got the same result you show with it checked.
Message 17 of 21
c.mateus
server!
Message 18 of 21
c.mateus
it worked, thank you very much
Message 19 of 21
blandb
That was a new one for me, never seen that before.
Message 20 of 21
CCarreiras
Não foi este caso e ainda bem, mas cuidado, trabalhando a partir do server pode corromper os ficheiros.
Já tive casos que aconteceram coisas similares ao que apresentaste, mas sem resolução, o trabalho teve de ser repetido.
A Autodesk sugere que se trabalhe localmente e colocar no server o trabalho finalizado e/ou as cópias de segurança.
Cumps.
CCarreiras
