i-Logic , stop updating model if DIMS are wrong or not allowed.
I am designing a ladder and I want the maximum number of steps to be 16.
User only provides the height, and the parameters create the number of steps.
So if the user provides a height that needs more than 16 steps there is a pop up message that informs the user that needs to give sorter height and at that point I want my model not to update and have the last working dimensions.
I was thinking maybe something like the break command (C++)?
I have also tried to loop the height so I can provide the closest dim to 16 steps but software seems to stop working.
Any thoughts?
If step_final > 17 Then
	MessageBox.Show("Steps must be less than 16, Please place a landing", "TECHNICAL SPECIFICATIONS")
	Do
		Heigth  = Heigth - 100
	Loop Until n_final < 17
End If
Curtis_Waguespack
Hi @Anonymous
Programming questions of this type are better asked on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
With that in mind for the future, I don't think the program stops working, but you are sending it into an endless loop. Without seeing your complete code , I think maybe something like the example below would work.
reference link
https://www.dotnetperls.com/for-vbnet
I hope this helps.
Curtis
oHeight = InputBox("Enter Ladder Height", "iLogic", 1500)
oLadderStep = InputBox("Enter Height of each step in the ladder", "iLogic", 100)
' This loop uses -Step to go down oLadderStep each iteration.
i = 0
For Actual_Height As Integer = oHeight To 0 Step - oLadderStep
	If i = 16 Then
		MessageBox.Show("Max number of steps is 16, Please place a landing", "TECHNICAL SPECIFICATIONS")
		Exit For 'exit loop
	Else
		i = i + 1
		'code to add step to model goes here
	End if
Next
MessageBox.Show("Number of Steps = " & i & vbLf & _
	"Actual total height is " & i * oLadderStep, "ilogic")
Hi, thank you for the reply and next time i will post these kind of questions at the correct forum.
This solution is not what I am actually after. I have my model designed in a way that steps are generated  by a pattern- i don't use i-logic for that-  and steps have only a minimum height that changes accordingly with the ladder's height. There is no other code everything else is at the parameters table. I was after a "stop" command like the exit loop that you wrote, but to prevent model to update when the user enters a "wrong" or too "big" dimension.
I will try definitely use the loop command in the future.
Thank you
After some time I manage to find a solution.
for future reference if anyone has a similar problem with me
'maximum number of steps is 16
If
n_final > 16 Then Heigth = 3000 mm MessageBox.Show("The maximum noumber of steps is: " & "16" & vbCr & "Ladder will automatically use the maximum height.", "Maximum Value Rule", MessageBoxButtons.OK, MessageBoxIcon.Error) End If
Thank you
