I am unable to find the option to save as 2023 or any file type that is compatible with the older version. Please help 🙂
Solved by swalton. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
It is not possible. If you want collaboration, you need one version. Parametric programs are not backward compatible.
Kacper Suchomski
Unfortunately, you need to download and install Inventor 2023.
I am not aware of a way to save an Inventor 2024 file in the 2023 format. The AnyCAD workflows that allow Inventor 2023 to open Inventor 2024 files do not give you a full model history tree.
If you have any important work in 2024, you will need to re-do it in 2023.
Steve Walton
All CAD software are NOT backward compatible.
Redo everything in 2023.
It's a good exercise.
You might find faster or better way to model.
And yes, I still do that after 20+ years using Inventor.
