12:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Link copied
@Anonymous Why would you?
Maybe you are looking for the "Add-Ins" button which is available on the "Tools" tab in the "Options" pane?
If you are reading something that says you should have a plug - ins tab please share the link to whatever you are reading stating that so we can better understand the issue.
Assuming you are talking about this... That isn't available for Inventor 2022..
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2540506896683021779&appLang=en&os=Win64
Note: coolOrange will not further develop the app or provide new versions for newer Inventor versions. The threadModeler for Inventor 2020 is the last version,
Hi! Try resetting Ribbon. Right-click on the Ribbon panel -> Reset Ribbon.
There is a way to make ThreadModeler work with Inventor 2021 and later releases. You need to read the comments under the ThreadModeler. There is an instruction to change an add-in xml file.
Many thanks!
