Inventor Forum
I can't open my file(ipt)
2 REPLIES 2
ehgml50
653 Views, 2 Replies
The following message appears: "Post restore of Object 000001F65AC84C00 meta-type PMxBodyEntry in segment PmBrowserSegment ends up causing a cycle)"
I want to restore my file.
2 REPLIES 2
SharkDesign
in reply to: ehgml50
Sounds like it's corrupted. Also see thishttps://forums.autodesk.com/t5/inventor-forum/inventor-2018-file-error-message/td-p/7161661
  Expert Elite
  Inventor Certified Professional
johnsonshiue
Hi! Indeed, likely the file is corrupted due to bad browser segment. You may want to share the file here or send it to me directly johnson.shiue@autodesk.com. I can take a look and see if there is a way to salvage it.
In the meantime, please go to \OldVersions\ folder at the same level to find the last saved copy. Rename the file extension to restore the file.
Many thanks!
Software Test Engineer
