I can't get Inventor to load
I  have installed Inventor but when I open it I get ; application was unable to start (0x0000142) click okay to close. Does anyone know wkat is wrong? I have windows 10 64 bit.
rhasell
Hi
I had a look at the various threads and it looks like 2014 is not supported on Windows10.
http://forums.autodesk.com/t5/inventor-customization/inventor-2014-is-not-compatible-with-windows-10...
What you could try, is to apply any possible install tricks/fixes for windows 8.1. This is just a thought, and have no idea if it will solve your immediate problem, at least until someone comes back with a definite answer.
Reg
2026.1
DannyHubbard
blair
You might want to look at the .NET and reinstall. If you seach this forum there are a couple of posts with respect to Windows 10. As also referenced, you should install all SP's and Updates as well for your version of Inventor.
Delta Tau Chi ΔΤΧ
