I can't delete Sketch
When drawing in the Sketch environment and using the Circular command to rotate the object, then I want to correct the Circular command or delete the Sketch, I can't delete it, please help me
-niels-
You are using the pattern function, so you can edit that (or delete) by right-clicking on any of the pattern's elements and selecting the desired option from the context menu:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
