I accidentally open a TMP. file on to Explorer
knox1ma
Message 1 of 10
knox1ma
Hello I accidentally open a TMP. file on to Explore. Now my drawing and part can't save. everytime I saw the part file i get this message " Cannot give a document the same name as an open document (or a document that is referenced by an open document, e.g. a part/assembly referenced by a drawing). Enter a different name for the document you want to save." I need help.
Here what is looks like
Replies (9)
Message 2 of 10
Frederick_Law
Close the "TMP" file with out save?
Which "TMP" file did you open? Which folder?
Message 3 of 10
knox1ma
it was the Autodesk inventor  that opens up when i clicked the dwg file. its in my own personal folder. its started with i accidently clicked the open always feature and clicked explorer and now when I clicked the dwg file and the tmp opens it open through explorer.
Message 4 of 10
Frederick_Law
Can you close the TMP file?
You have other files opened in Inventor?
Message 5 of 10
knox1ma
I'm sorry but that wasn't  the solution
Message 6 of 10
Frederick_Law
You do understand I can't see your computer and can't help you much with what you given here.
Message 7 of 10
knox1ma
sorry I don't know much of what is going on myself. all I know is my file every time I open HHT -6764 dwg.file it open the tmp. file into Explorer. This happen because I accidentally clicked the always open to explorer when it open with. Now when I save it I get this message " Cannot give a document the same name as an open document (or a document that is referenced by an open document, e.g. a part/assembly referenced by a drawing). Enter a different name for the document you want to save." I'm trying to get the tmp file to not open in explorer but im not having much luck.
Message 8 of 10
Ed__Jobe
You need to reassociate AutoCAD or Inventor with the dwg extension. After you select 'Choose another app', make sure that you check the box to 'Always use this app' and then select the desired application.
Ed
How to post your code.
Message 9 of 10
pcrawley
In Windows File Explorer, you need to unhide the file extension.
In Windows 11, you'll find that function here:
Now locate the problem file.
You will see the last part of the file name reads ....PRINT NEW.9780.dwg.tmp
Rename the file by deleting the .tmp extension.
The drawing (assuming it is a drawing!) should now open with AutoCAD.
Peter
Message 10 of 10
knox1ma
can I use AutoDesk Inventor pro?
