How to use the orientation command in a rectangular pattern?
260717G4TH5
260717G4TH5
Community Visitor
Community Visitor
I've been trying to model a custom chain for a while now. This present attempt has led me to trying to use the rectangular pattern in tandem with an associative pattern. I initially had difficulty using the associative pattern to model relative orientation, however after finding the orientation dialoug in the rectangular pattern I figured out how to model orientation and am left with whatever this problem is, I request assistance.
kacper.suchomski
Hi
The first occurrence of the component must be in the same location as the first occurrence of the feature element in the base pattern.
P.S. If you found the item I indicated in the previous discussion, please mark the solution to the topic.
Kacper Suchomski
260717G4TH5
Community Visitor
Community Visitor
260717G4TH5_0-1759176207174.pngsetting it to the same location worked thank you, this is the itme I found in the previous discusion so I will explain the soluton an dmark it complete thank you again.
