How to make a custom chain?
260717G4TH5
Message 1 of 13
260717G4TH5
Community Visitor
Community Visitor
I've been trying to model a chain for my vex robot for years now, and every time I've just left it out. Is there a way to either add a chain link to the roller chain list, or to add relative rotation to allow me to model them with an associative pattern.
I've tried using an associative pattern (it's a circle just as a proof of concept) but they all maintain the same rotation, is there any way to do some kind of relative rotation with a pattern in an assembly?
Replies (12)
Message 2 of 13
kacper.suchomski
Hi
The direction of the associative pattern follows the source pattern.
Did you give direction to the elements in the base pattern, or did you allow them to maintain a fixed orientation?
Kacper Suchomski
Message 3 of 13
260717G4TH5
Community Visitor
Community Visitor
I just used the insert constraint to attach the chain lick to the base element of that pattern. You’re saying that if I used a a second constraint to a sequential element in the pattern it would maintain a relative orientation?
Message 4 of 13
kacper.suchomski
I didn't mention anything about constraints.
I asked if you had defined the direction of the base pattern elements.
Kacper Suchomski
Message 5 of 13
260717G4TH5
Community Visitor
Community Visitor
I’m afraid I don’t understand what you mean about instructions, sorry. Could you please elaborate?
Message 6 of 13
kacper.suchomski
How did you create the cell pattern?
Kacper Suchomski
Message 7 of 13
260717G4TH5
Community Visitor
Community Visitor
I made the pattern by making a rectangular pattern of a small cylinder made from an extrusion of a circle, along the length of a circle, all in the part level. Then in an assembly, i brought in my chain link and constrained it with an insert on to one of the cylinders in the pattern. Finally, i used an associative pattern on the rectangular pattern and inserted chain link to creat the above chain.
Message 8 of 13
kacper.suchomski
Did you define the orientation of the pattern elements according to the direction, or did you keep the orientation of the elements in the pattern constant?
Kacper Suchomski
Message 9 of 13
260717G4TH5
Community Visitor
Community Visitor
I did not define orientation, this may sound stupid, but how do I define orientation?
Message 10 of 13
kacper.suchomski
In the pattern dialog box there is an item called Direction.
Kacper Suchomski
Message 11 of 13
260717G4TH5
Community Visitor
Community Visitor
They only options i see are feature and pattern selection.
Message 12 of 13
kacper.suchomski
No one knows what you see until you show it.
Kacper Suchomski
Message 13 of 13
260717G4TH5
Community Visitor
Community Visitor
Sorry I’m not at my of rn, I’ll get back to you when I am
