I have an assembly which is a compound of sub-assemblies. I notice a discrepancy between (for example) levels of two base plates. I change the relevant PART to adjust and fix the discrepancy. In my understanding, updating the top-level assembly should update everything through the levels. Is that correct?
Also, how do I update the top-level assembly without closing and re-opening it?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
