How to update an assembly
Vagulus
Vagulus
I have an assembly which is a compound of sub-assemblies.  I notice a discrepancy between (for example) levels of two base plates.  I change the relevant PART  to adjust and fix the discrepancy.  In my understanding, updating the top-level assembly should update everything through the levels.  Is that correct?
Also, how do I update the top-level assembly without closing and re-opening it?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Xun.Zhang
Hello @Vagulus,
Go to Manage -> Update -> Rebuild all.
Hope it helps!
Xun
Vagulus
Thanks.  I new there'd be a way.
Albert Einstein
SBix26
Also, there is the Update button on the tool bar Update Button.png which lights up when there are updates available.  This does not do a full rebuild, but is much quicker and should do what you are asking.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
