Hi, I wanted to ask for help with an annoying feature of Inventor 2019.
The problem is illustrated here: https://imgur.com/a/uNqoJxZ
In short: from the content center I placed an 80x80x3 rectangular beam. I want to create a support for a table top, so I need four of those. I created a circular pattern with a rotation to nicely place four beams to create a frame.
As the last step, I would like to put a constraint between the beams (pattern elements) so they are not loose (faces marked with blue lines in the album). However, I am unable to select a second face of the beam, I can only choose a different part (e.g. the table top).
Is this a feature or is something wrong with my inventor? Thanks for the help!
