how to unfold the curve object in sheet metal
I want to unfold the attach 3D model, I am using Inventor 2016. Thanks in advance.
Xun.Zhang
The data you shared is not a sheetmetal file with inconsistent thickness.
Please try Unwrap command in Inventor 2020 to solve it.
Hope it helps!
Xun
S_May
@Anonymous ,
i only have inventor 2018, it also works in inventor 2016
2019-06-04 10_12_10-Autodesk Inventor Professional 2018 - [_cable_car_1.ipt].png2019-06-04 10_12_21-Autodesk Inventor Professional 2018 - [_cable_car_1.ipt].png
S_May
@Anonymous
Inventor 2020... 2019-06-04 10_22_06-Autodesk Inventor Professional 2020.png
Thanks for reply, I am unable to open the same in inventor 2016, showing version issue. Kindly share the process, so I can do the same on my part file.
S_May
