How to turn a 3D solid into a shell
hugolopessilva1
hugolopessilva1
Community Visitor
Community Visitor
hi,
I have a 3D part that I need to edit, in order to become a shell (no thickness). How can I do it? I already tried the shell command, but it only reduces the thicknesses to me.
I thank you in advance,
Best regards,
CGBenner
@hugolopessilva1
Welcome to the community!
Can you please share your part, or even a screenshot of the part so that we can give you the best advice possible?
Chris Benner
-niels-
Either delete a face or use "copy object" i think...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
CCarreiras
Just another option:
Use Thicken, (Surface mode) to select each face you need for the shell surfaces set distance to zer0.
If it is all the faces, just drag a selection box over the entire solid.
Delete the solid: Use Delete face tool, in solid mode to delete all the solid (and not a few faces).
In solid mode, just select the solid.
That´s it, here's the result.
CCarreiras
cadman777
Just delete one or all of the faces you don't want to keep.
That will automatically turn it into a SURFACE, which is a 'shell without thickness'.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
johnsonshiue
Hi Hugo,
I guess you would like to have an enclosed surface body instead of a solid body, right? You can use Thicken/Offset command, set output to Surface, select all the faces, and set the distance to 0.
Many thanks!
Software Test Engineer
