Inventor Forum
How to switch everything in an assembly to metric
6 REPLIES 6
chan67
1324 Views, 6 Replies
So I have a big assembly that is done in inches.
I am now really fed up with it and want to change every single sub assembly and part file in it to mm and kg.
How do I do that? I can change one part/sub assembly at a time from document settings, but I want to change everything at once. I have already set the default to mm and ISO but it didn't seem to make a difference.
6 REPLIES 6
machiel.veldkamp
in reply to: chan67
If you want to do that all at once you might want to take a peak at iLogic.
The folks in Inventor customization might be able to help you start out 🙂
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
___________________________
WHolzwarth
in reply to: chan67
Sergio.D.Suárez
in reply to: chan67
Hi, try to execute the following ilogic code at the main assembly level.
If it works, remove the asterisk in the line
'docFile.save
not what I removed before because if it does not work well, I would save the file with an error, for security I avoid saving the file in the codes until I am sure that they work as I want.
Dim oLengthUnits As String = 11269
Dim oMassUnits As String = 11283
Dim oDoc As Document= ThisDoc.Document
oDoc.UnitsOfMeasure.LengthUnits = oLengthUnits
oDoc.UnitsOfMeasure.MassUnits = oMassUnits
For Each docFile As Document In oDoc.AllReferencedDocuments
	On Error Resume Next
	docFile.UnitsOfMeasure.LengthUnits = oLengthUnits
	docFile.UnitsOfMeasure.MassUnits = oMassUnits
	'docFile.Save
	docFile.Rebuild
Next
'---------LENGTH UNITS--------------
'kFootLengthUnits 11273 Foot Length
'kInchLengthUnits 11272 Inch Length
'kMillimeterLengthUnits 11269 Millimeter Length
'kCentimeterLengthUnits 11268 Centimeter Length
'kMeterLengthUnits 11270 Meter Length
'kMicronLengthUnits 11271 Micron Length.
'---------MASS UNITS---------------
'kLbMassMassUnits 11286 LbMass Mass
'kSlugMassUnits 11285 Slug Mass
'kGramMassUnits 11284 Gram Mass
'kKilogramMassUnits 11283 Kilogram Mass
 This rule will change the units of your assembly and all assembly reference files.
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
lena.talkhina
in reply to: chan67
Hello @chan67 !
Great to see you here on Inventor Forum.
Did you find a solution? Don't hesitate to click the green button below the post to accept the solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
chan67
in reply to: Sergio.D.Suárez
One part (only one as far as I can tell) got deleted for some unknown reason and it broke my assembly. Other than that it seems to work fine. Maybe some problem with the loop?
(don't worry I backed everything up)
WHolzwarth
in reply to: chan67
No one knows. Without seeing the files.
Walter Holzwarth
