Lets say I want to make a 3D projection of a cirlce from the face of a mobius strip. I can make the mobius strip, but how do I make a projection from it since at any point. I have a file, and an example I would like to create.
Thanks so much.
Solved by CCarreiras. Go to Solution.
Solved by WHolzwarth. Go to Solution.
Hmm. Your Bend part solution is looking strange. I'm in doubt, if it's ok.
Therefore I tried to use an equation curve. In Wikipedia I found this:
With and
Now you can create edge curves for the strip, one with r=-1, the other with r=1. Alpha is changed to t, range between 0° and 360°.
Well, this works ok from 0° to 331°. But what's going on with tmax between 332° and 360°?
😉 Can you hear me, Johnson?
Walter Holzwarth
