Hi
How to show a bolt thread line in drawing ?
Rgds
Kiri
Hi Kiri,
Try to edit the view, enable 'Thread Feature' to display it.
Hope it helps!
Thanks Xun,
I tried, it only shows the hidden parallel vertical lines, not like a actual thread lines ( in an angle ).
Is there any way to show that ?
Rgds
Kiri
Hi Kiri,
I don't think there is an easy way to handle the actual thread line like yours.
Would you mind to record it in ideastation if you want.
Thanks!
real thread as visual and 2 drawing?
convert first to ThreadModeler
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2540506896683021779&appLang=en&os=Win32_64
