How to set thread type option order
toznal
toznal
Hi there!
I have a question about thread option order!
I usually use ISO Metric profile. But It's set up ANSI Unified Screw Threads as default.
Is it possible to change thread option order to ISO Metric profile?
Thank you
johnsonshiue
H!! This can be done by changing the sort order in the Thread.xls file. Go to \Design Data\xls\ and find Thread.xls. Edit the file in Excel. Each sheet represents one standard group. Look at the top row. There should be a cell "Sort Order -x." Change it accordingly. Make sure the order is unique. You should not have two sheets with the same sort order.
Many thanks!
Software Test Engineer
toznal
Hi! oh Thank you!
You saved me.
thank you ! have a great day!
Superb sir....! @johnsonshiue
Thanks,i was searching form long time. This reduces my work time.
