Hello, everyone!
These days i was creating a lot of iparts,and then released them to content center library ,and then create new hose styles,but at last,it can't be saves,there's no warning,so i can't find why,i was suspecting the end treatment was wrong,but after i changed to others there was nothing changed.
So ,how to set the end treatment of hose to hose connector?do you have some pdf instructions for me? thank you very much!
The AVI file does not play, so not sure what you are trying to do. Try to find inspiration based on image:
- open an existing hose fitting (used in hose style) from Content Center (As Custom) ant try to authorize it, see how it is authorized and make you part authorized similar way
Regards
Jan Priban
If the advice that @jan_priban gave you does not answer the question, please attach your part here so that someone can take a look at it. Thanks!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thank you very much,i have turned to the last step,but i failed to save, the screen print showed below.
Today someone told me in 2021 inventor ,he successed to save a new hose style with my SAME parts.but mine is 2019version.😓
If you attach your part file for the fitting, maybe we can try to figure this out.
Chris Benner
