How to secure a Content Center Library?
W.Scott.Dempster
Message 1 of 9
W.Scott.Dempster
I am setting up a Content Center Library to be used in my Vault server. I would like to secure the Library so only myself or select users are able to make modifications to it.
Are there any methods to achieve this?
Replies (8)
Message 2 of 9
Frederick_Law
I've added a Lifecycle that other don't have permission to change it.
Or use admin account to check it out.
Message 3 of 9
W.Scott.Dempster
Can you clarify what you are checking out? I assume the Project file? Or is there a way to check out the Content Center Library?
Message 4 of 9
Frederick_Law
Check out the library files.
Message 5 of 9
W.Scott.Dempster
Is that the iPart Factory file you use to publish to the Content Center or something different? Sorry, just struggling to find what other Library files there are on my Vault server.
Message 6 of 9
Frederick_Law
So what are you trying to lock?
The CC Library or the parts created by the library?
Message 7 of 9
W.Scott.Dempster
The CC Library. For example, I would like to prevent people from changing properties of Members within it, like Part Number.
Message 8 of 9
Frederick_Law
Library is the idcl file.
It will generate ipt which user could edit also.
Message 9 of 9
CGBenner
@W.Scott.Dempster Did the information provided by @Frederick_Law answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
