Inventor pop ups / Menu Boxes Not Showing
Does anyone else ever have the issue on Inventor 23 where they will create a drawing, press "Base View" and nothing happens? The command becomes active but the dialog box and view doesn't actually appear so you can't place a view? This is generally the one I notice it with, but it does seem to stop all of these type of boxes appearing. So when I create a drawing for example we have prompted field text that gets filled in this also doesn't appear when we have this issue. The fix we have it to close Inventor and reopen it but, it's obviously annoying to do so.
If I've helped you out drop the post a like, if I've given you a solution mark as solved. It's us, 'The community' that makes this place work 😄
