Inventor Forum
How to roll up a hose around cylinder/tube?
7 REPLIES 7
Message 1 of 8
taddeo.guerin
533 Views, 7 Replies
Is it possible to roll up a flexible hose around a cylinder/tube?
Like in this video : https://www.youtube.com/watch?v=2_Mlk2jDUok
I was able to create a pipe but I don't know how to wrap it around a cylinder.
Thanks for your help
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: taddeo.guerin
Parameters for Coil and Extrude.
Animate Parameters.
But in the video you linked it is actually a Trace in Dynamic Simulation.
Inventor 2022 Help | Trace Dialog Box | Autodesk
Message 3 of 8
taddeo.guerin
in reply to: JDMather
Thank you for your answer.
I know it's a trace on the video, but I shared it to show the path my hose will have to follow.
Can a hose created with this option be pulled and coiled like in the video?
Message 4 of 8
JDMather
You will have to do a Coil and an Extrude and then Animate Parameters.
How much experience and training do you have with Inventor?
What version of Inventor are you using?
Message 5 of 8
taddeo.guerin
Ok thank you.
Can we transform the material of a hose created with the "coil and extrude" option into a soft and flexible hose?
I am using the 2020 version and have only a few months experience with this software.
Message 6 of 8
A.Acheson
As @JDMather mentioned using coil and extrude would get you the coiled hose in a part environment.
If you want to create it in a tube and pipe environment and apply the material styles you can derive the 3d sketch to use as the route for flexible hosing.
As for simulation I would think bringing in tube and pipe add in would further complicate this as it will be a difficult enough task in the normal part environment.
Regards
Alan
Message 7 of 8
SBix26
This model uses a 2D sketch wrapped around a cylinder and flat face to create the path for a sweep.  Animated using the Studio environment.
And here's a render of it unwinding: https://autode.sk/3a36vQB
Never mind, that doesn't work.  See attachment.
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
Message 8 of 8
Thank you all for your answers.
Even if I don't understand everything, because of my inexperience with the software, it helps me to understand how to do it.
