How to roll up a hose around cylinder/tube?
taddeo.guerin
taddeo.guerin
Is it possible to roll up a flexible hose around a cylinder/tube?
Like in this video : https://www.youtube.com/watch?v=2_Mlk2jDUok
I was able to create a pipe but I don't know how to wrap it around a cylinder.
Thanks for your help
Replies (7)
JDMather
Parameters for Coil and Extrude.
Animate Parameters.
But in the video you linked it is actually a Trace in Dynamic Simulation.
Inventor 2022 Help | Trace Dialog Box | Autodesk
taddeo.guerin
Thank you for your answer.
I know it's a trace on the video, but I shared it to show the path my hose will have to follow.
Can a hose created with this option be pulled and coiled like in the video?
JDMather
You will have to do a Coil and an Extrude and then Animate Parameters.
How much experience and training do you have with Inventor?
What version of Inventor are you using?
taddeo.guerin
Ok thank you.
Can we transform the material of a hose created with the "coil and extrude" option into a soft and flexible hose?
I am using the 2020 version and have only a few months experience with this software.
A.Acheson
As @JDMather mentioned using coil and extrude would get you the coiled hose in a part environment.
If you want to create it in a tube and pipe environment and apply the material styles you can derive the 3d sketch to use as the route for flexible hosing.
As for simulation I would think bringing in tube and pipe add in would further complicate this as it will be a difficult enough task in the normal part environment.
Regards
Alan
SBix26
This model uses a 2D sketch wrapped around a cylinder and flat face to create the path for a sweep.  Animated using the Studio environment.
And here's a render of it unwinding: https://autode.sk/3a36vQB
Never mind, that doesn't work.  See attachment.
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
taddeo.guerin
Thank you all for your answers.
Even if I don't understand everything, because of my inexperience with the software, it helps me to understand how to do it.
