I have a .dwg and .iam in Inventor 2024 and Vault Pro 2024. Changes were made in several of the latest versions that need undone, and a previous version be the latest. For example, the .iam has 21 versions and I would like to remove versions 21 and 20 to have version 19 be the latest. How do I do this? While using an administrative vault account, I get this error message when trying to roll back to a previous life cycle state. "One or more files have restrictions that prevent roll back of lifecycle state change for all selected files. The operation will be cancelled. Affected Object: [file name]. Restriction: There is no valid lifecycle state to rollback to." I also tried to "Get" version 19 from Vault, open version 19 in Inventor, and then check version 19 in, but the check in and check out options are greyed out when I do this. Please note that I am unable to upload any files to the forum due to conflicts with private data.
Solved by Ray_Feiler. Go to Solution.
Hi! Could you take a look at the following article?
Many thanks!
I tried following the screencast shown on that link, but I do not know what I'm doing wrong. When following along with the workflow and I click "Roll Back Lifecycle State Change", I get the message "One or more files have restrictions that prevent roll back of lifecycle state change for all selected files. The operation will be canceled. Affected Object: [file name]. Restriction: There is no valid lifecycle state to roll back to." unlike the screencast shows.
To revert a file to a previous version and make it the latest in Autodesk Vault Pro, follow these steps:
Get a Local Copy:
Roll Back the Lifecycle State:
Remember that rolling back to a previous lifecycle state requires a state change to have taken place, and reverting to a previous version of a file requires that the previous version was checked in. Vault cannot be used to revert changes to files that were made but not subsequently checked in.
