XML that stores AddIn load/unload etc Settings
ChristiPedersen
ChristiPedersen
Is there an XML file that stores the add-in load/unload/block settings?  This would be helpful at upgrade time.
johnsonshiue
Hi Christi,
The addin control xml files are installed in C:\Program Files\Autodesk\Inventor 2025\Bin\Addins\ (for 2025). If those files are removed, the addins will not load.
The user-specific addin control xml files are stored in %AppData%\Autodesk\Inventor 2025\Addins (for 2025). These are overrides to the install default settings.
Many thanks!
Software Test Engineer
ChristiPedersen
Hi Johnson, I looked through there and only found 1 "AddInLoadRules" but there doesn't seem like there is anything in it that is readable or editable.  Like application options, I am looking for a way I can default what is loaded/unloaded for addins when we upgrade.  Many things come loaded that not all users would use and we want to run lean to start.  The users can then load additional things as they need them.  The picture attached is what I am looking to "preset" on upgrade similar to application options.
johnsonshiue
Hi Christi,
Did you look into the Bin folder? That is where you could set right after install regardless of the users. For user specific control, you will go to %AppData%. It works on an override basis. Only the only is disabled or changed from the default behavior will have .addin files there.
Many thanks!
