How to remove all the horizontal and vertical constraints
gparamasivam
Message 1 of 15
gparamasivam
Hello Everyone,
How to remove the all horizontal and vertical constraints in all the sketches with single shot or automatically.
If is this possible, Kindly guide me..
Advance Thanks...
Replies (14)
Message 2 of 15
Casey.P
Hi @gparamasivam ,
So far, the best way I figured is if you hold control and left click select the constraints that you want to delete. Once you have them all selected, just hit the delete button....
You could window drag and then deselect all of the features and constraints that you don't want to delete, but I think this section option will take longer.
Message 3 of 15
JDMather
Rotate.
Message 4 of 15
imajar
I think @JDMather  solution is the best to solve your specific problem, but you can also select all the geometry, right click and select delete all constraints.  The drawback, is it will also wipe out the other constraints (except coincident).
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 5 of 15
JDMather
Can you Attach your file here?
I can't help but wonder why you would want to do this.
In 15 years of using Inventor - I have never seen this need posted here before.
Turning the sketch into a Sketch Block, might be another option...
Message 6 of 15
gparamasivam
It will delete the all parallel and perpendicular constraints also,
I need only delete the horizontal and vertical constraints
Message 7 of 15
gparamasivam
In iFeature sketches should not have the horizontal and vertical constraints because it may cause make some issue on iFeature. So we have a to do not use horizontal and vertical constraints in iFeature sketches.
Hope you will understand our issue.
Message 8 of 15
JDMather
Ah, now I understand.  And I was incorrect in my previous statement. 😮
Message 9 of 15
gparamasivam
No problem, thank you for your suggestion
Message 10 of 15
CGBenner
@gparamasivam  Did the information provided by answer your question? If so, would you please use Accept Solution so that others may find this in the future? Thank you very much!
Chris Benner
Message 11 of 15
gparamasivam
No, still I did not get the right answer
Message 12 of 15
CGBenner
@gparamasivam
Aside from the suggestions you have received here, I think you might be looking at the need to create an iLogic solution to do this automatically.  I'm not certain that it is even possible with iLogic, but you could try posting in the Inventor Customization forum, maybe one of the experts there will have a suggestion.
Chris Benner
Message 13 of 15
gparamasivam
Thank you for your suggestion
Message 14 of 15
mcgyvr
@gparamasivam
Here you go this will delete all horizontal and vertical constraints in a part in all sketches..
Dim oPartDoc As PartDocument
Dim oSketch As PlanarSketch
Dim geoconstraint As GeometricConstraint
On Error Resume Next
oPartDoc = ThisApplication.ActiveDocument
For Each oSketch In oPartDoc.ComponentDefinition.Sketches
For Each geoconstraint In oSketch.GeometricConstraints
	If geoconstraint.Type = kHorizontalConstraintObject Then
		'MsgBox ("Deleting Horizontal Constraints")
Call geoconstraint.Delete
Else If geoconstraint.Type = kVerticalConstraintObject Then
			'MsgBox ("Deleting Vertical Constraints")
Next geoconstraint
Next oSketch
MsgBox ("All Horizontal and Vertical constraints deleted!")
Message 15 of 15
gparamasivam
Thank you,
It is working and very useful to us.
