Hi, I've created iAssembly (.iam) on inventor. I want to publish it on content center now. There are possibilities for iParts (.ipt) publish into Content Center on Under Manage Tab. Please advise me how to publish .iam (iAssembly) file on content center?
Solved by Mark.Lancaster. Go to Solution.
Solved by Marco.Takx. Go to Solution.
If its possible to publish somewere else that's fine, I could import from there. I wanna publish iAssemblies on inventor. Ive understood about iAssembly functions, But my case is i wanna publish it. Please give me an idea/Tips for if i use any other 3rd party tools? .
There's no way of publising an iAssembly member and no 3rd party tool to do that for you. So what is the requirement for you that you need to publish an iAssembly for? That way we can give you advice on what to do next.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks for the reply. My requirement is i wanna make content center part familes on dev server with two or more than different parts (.ipt) on Autodesk product, Like Inventor/CAD. It would be an different materials and features of iparts, So pls advise me how to approach on my projects?
Well as we indicated that is not possible. Content Center is only designed for parts. Just make your iAssembly with the required parts/material configuration. Then in the iAssembly table in your model, right mouse click on a member and select generate member. Then you can select the generate members to place in other assemblies. There's nothing else you can do except create a normal assembly and use iLogic to swtich the components.
Mark Lancaster
I just re-read your posting...
It would be an different materials and features of iparts, So pls advise me how to approach on my projects? --> So are you now talking about creating just a single part and then have different material for it? Or are you still referring to your assembly that would have similar parts with different materials.
Mark Lancaster
It's both are different material and feature (.ipt), Then i'll make/use it on Assemly. In assy condition i need provide different size ranges for PartFamily Members.
So make an iPart with the different features and materials. Then place the ipart in your assembly and then make an iAssembly from there. Then config your iAssembly table with the different iPart members.
Mark Lancaster
Hi, I've tried that way of creating iAssy. When i placing iPart on assembly it's asking single size(Single material), So i could insert an more than one material on iAssy then i can create iAssy table with using different types of material ranges, Thats fine. But it not able to publish on the content center as iPart as Mark. Lancaster and Marco. Takx said, So i like to close my question and I would like to discuss to add this option in future for any Autodesk Product, Because i am using iAssy with defferent material on my project and i wanna publish them as well. Thanks.
