Boy, ... am I out of practice!
I am trying to make a note of the scale of a drawing
but I have forgotten how to enter the value.
I searched my text (Waguespack) without luck.
Would someone please step me through it.
Solved by -niels-. Go to Solution.
Do you want it placed around the view, or in the Title Block?
If you want it around the view, check these options when placing the view (looks different in IV2018 compared to older versions)
Thanks for that but I am not looking to set the scale for the drawing. I am looking at placing a note on the drawing advising the user of the scale.
The annotation would read, "SCALE: 2:1" or somesuch, but I seem to recollect that the value can be set in the annotation from Inventor - note written manually.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Well, naturally you can only set the scale based on one view.
Personally I'm using an addin by the Danish company NTI to create a custom iProperty with the scale of the first view printed. I can then use that iProperty to use in a standard annotation.
That is doable by iLogic as well, but I seem to have thrown that piece of code away.
I tihnk it was posted on InventorTrenches blog at some point.
Edit:
@-niels- Wasn't that added in 2018? Or has that been there for multiple versions?
Thanks for that. I knew it was there somewhere.
Niels van der Veer
The Netherlands
I see.
Probably missed the change because we were using iLogic to handle it back in 2013 when I started using IV.
Ever since then we just migrated and missed it
