Inventor Forum
How to mirror component with constraints
6 REPLIES 6
1143 Views, 6 Replies
Im wondering if anyone can help as to how to mirror the endcap in the screen shot to the other 3 exposed uprights, to fit on the top aswell as the bottom.
I can mirror them no problem however the constraints dissapear when mirrored. Ive heard about creating a pattern but im not quite sure that it will help...
Any suggestions would be appreciated,
Cheers.
Benjieng
6 REPLIES 6
mdavis22569
Why mirror it ....
just pattern it
put one on the bottom of the same extrusion ..and pattern them both together instead
Mike Davis
in reply to: mdavis22569
And how would i go about doing that?
Ive selected both end caps....now what.
CCarreiras
Hi!
Are you doing it with "Frame Generator" or manually?
CCarreiras
in reply to: CCarreiras
Frame generator.
mdavis22569
https://www.youtube.com/watch?v=a4d-O21ik3k
From the picture you posted ...
Pick the item like you did ...then go the square
then you will get a new box ..and you will pick the edges for the direction you want the pattern, you can put in the distance and how many ..
Mike Davis
CCarreiras
How many are they?
6? 8?... Just constrain them manually and stop your problems with mirrors and patterns with "flying parts" 🙂
It will take few minutes... and you will have a more robust assembly.
CCarreiras
