- Mute
- Permalink
- Report
I use 3D sketches for some elements of our design, but struggle a bit to get them properly consistent. Several issues could be mentioned, but the most cumbersome is when sketch elements flips. The dimensions have no ‘direction vector’, so when the sketch is solved after a reference change you never know if a constrained line points up or down.
The Screencast shows a lifting set defined by the lifting height needed in the Assembly. This height controls a 3D sketch used to define slings, shackles and lifting head. This is a very simple 3D-sketch, but still the small 66.5mm line flips when the height is reduced.
Any proposals on how to lock the direction to upwards?
(Note, even if the line colors indicate that the sketch isn’t fully constrained, I don’t think any constraints are missing. But for a 3D-sketch you never know for sure, here you have no indication of remaining degrees of freedom)
Torbjørn
(Inventor 2017.3)
