Diameter of the ring when compressed = diameter of the cylinder in which it is compressed.
For example, if I want to make a cone, I can use sheet metal to design the cone. so I can find out the dimensions in sheet form
This is not logic - the differences in sheet metal are calculated; and the diameter of the ring is measured. These are different processes.
Following the analogy to sheet metal, you can assume a scenario when:
- You exact know all the dimensions of the expanded ring.
- You know the diameter of the cylinder - i.e. the diameter of the ring after compression.
- You know the location of the neutral axis of bending (k-factor)
- You use the above information to calculate (automatically, inside the program) the remaining dimensions after compression - for example, the distance between the ends.
And once you know the dimensions - Use model states to manage individual parameters.
