Solved by mcgyvr. Go to Solution.
Solved by jhackney1972. Go to Solution.
Seems not being possible.
Workaround could be thickening of a boundary patch, created from an offset curve.
2015 IPT attached.
Walter Holzwarth
2015 IPT attached.
Walter Holzwarth
Can you post your 'Part 5' here? What version of Inventor are you using?
On the face of it, this looks easy to do, but it would help to know how you started your rectangle and how big you want the rib to be.
Sam B
Inventor Pro 2021 RTM | Windows 10 Home 1903
LinkedIn
Sam B
LinkedIn
As @WHolzwarth says the Rib command cannot handle it. I think a sweep is a good choice to create the feature.
John Hackney, Retired
Just another extrusion..
