Inventor Forum
How to make an external rib on a box
4 REPLIES 4
rickNX3LL
579 Views, 4 Replies
rickNX3LL
How do i make this a continuous rib around the rectangleHow do i make this a continuous rib around the rectangle
4 REPLIES 4
WHolzwarth
in reply to: rickNX3LL
WHolzwarth
Seems not being possible.
Workaround could be thickening of a boundary patch, created from an offset curve.
2015 IPT attached.
Walter Holzwarth
2015 IPT attached.
Walter Holzwarth
SBix26
SBix26
Can you post your 'Part 5' here?  What version of Inventor are you using?
On the face of it, this looks easy to do, but it would help to know how you started your rectangle and how big you want the rib to be.
Sam B
Inventor Pro 2021 RTM | Windows 10 Home 1903
LinkedIn
Sam B
LinkedIn
jhackney1972
jhackney1972
As @WHolzwarth says the Rib command cannot handle it.  I think a sweep is a good choice to create the feature.
John Hackney, Retired
mcgyvr
in reply to: jhackney1972
mcgyvr
Just another extrusion..
