Using Manage/Insert Object tool I can easily insert a PDF into a drawing IDW file but it always inserts only the first page of a multi-page PDF.
Is it possible to somehow insert the other pages in the PDF? There does not seem to be an option for that.
I'd like to insert each PDF page on a different IDW sheet # for example.
It doesn't seem to be able to do that. A workaround would be to save each pdf sheet separately and then insert it.
But I don't think that you are looking for that. May I ask why you want to include many PDF's in your IDW's?
Kind regards,
Joshua
Hi! Only the first page is shown in the OLE object. To show other pages, you will need to move the desirable page to the top and save the PDF as a different file. Then insert it to Inventor.
Many thanks!
