Inventor Forum
How to import a border onto a finished drawing?
5 REPLIES 5
daniel.bracken
822 Views, 5 Replies
daniel.bracken
Hi all,
I am currently struggling with an issue on my version of Inventor LT 2019.
I have a border that I use for drawings inside my company and a border that I use to send drawings out to customers.
(Confidentiality issues).
I have done a drawing on one border and now decided it needs to be on the other... how can I replace the border on that drawing without having to "re-draw" it all again?
Help?
Hi all,
Help?
5 REPLIES 5
mdavis22569
Make sure the border you want to change it to is in the IDW / DWG
Is it's not, go to the browser and copy it out from the Drawing Resources / Borders folder and paste it into the new one:
Delete the existing and then insert the new one you want
Mike Davis
Mike Davis
SER4
in reply to: daniel.bracken
SER4
Please vote for this idea if you are sick of having to first Delete the existing, and then Insert (when it should simply be a "Do you want to replace existing?  Yes/No/Cancel" dialogue box):
https://forums.autodesk.com/t5/inventor-ideas/make-it-faster-to-change-title-blocks-borders/idi-p/11...
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
mdavis22569
in reply to: SER4
mdavis22569
@SER4
Don't need too ..
Also believe you can do it via iLogic too now ...
The link you share has been accepted:
Status changed to: Accepted
Mike Davis
@SER4
Don't need too ..
Mike Davis
SER4
SER4
My bet is whatever has the most votes actually gets implemented first...Something can be "Accepted" and take years to be implemented.
mdavis22569
in reply to: SER4
mdavis22569
and it could be removed ...
But cost also comes into play.    Doesn't matter if it's the most votes,
Also, it's what else is affected by doing this automation too.
Mike Davis
Mike Davis
