Inventor Forum
How to identify "dimensions needed" to have a fully constrained sketch?
4 REPLIES 4
jeffrey.s.barrero
5831 Views, 4 Replies
Good morning
      Is there a way to have Inventor suggest, point, highlight, etc, the "dimensions needed" to have a fully constrained sketch?
I keep trying to apply more dimensions, but I keep getting a "Adding this dimension will over-constrain the sketch. Choose Accept to create a driven dimension"; even if I accept the driven dimension, it still shows 2 dimensions needed.
Any advice to avoid running in to this issue will be greatly appreciate it, and if I have to completely change the my approach to sketching; will be happy to.
Thank you for taking the time to read my post, and wish you a great day
Tags (1)
4 REPLIES 4
in reply to: jeffrey.s.barrero
Project the origin center point if it is not already.
Constrain a point on your sketch to that.
If all else fails, use the auto-dimension to help you figure out what is under-constrained.
As @john.retzlaff suggested, the Automatic Dimension and Constraint command can be used.  The problem with this tool is that it will place dimensions poorly or give a solution you do not want.  I would recommend to only use this tool to give you a hint as to what dimensions are missing.  Watch the screencast, I try to explain it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thank you so much, for your time and effort to answer my question. I have to say, that I am baffled of how much the features in this forum have evolve since 4 years ago; I also stumble my way thru and struggle getting around. I will make an effort now and familiarize my self, so that I may contribute back to the community as you fine gentlemen.
Thank you very much and wish you a great day.
It may not need dimensions, as well as the previous suggestions & assuming your sketch is symmetrical, you could make the angled lines equal to each other. Same with the 2 vertical lines.
Technology Administrators
