Zip and Attach example file here that you are having trouble with.
@manhcn wrote:
Hi!
How to hide dimesion in 2D drawing? Its possible ? Thanks so much!
In a 2d drawing (meaning an idw/dwg file) if you don't want to see a dimension simply delete it..
Or select the dimension and assign it to a different layer (maybe create a new layer) and simply turn the visibility of that layer off..
If by 2d drawing you actually mean a part sketch then no you cannot hide individual dimensions.. You can turn the visibility of all dimensions in a sketch off though by simply right clicking on that sketch and selecting visibility
@mcgyvr is correct.
Maybe if you explain why you want to do this, we can offer a better alternate way to do what you are trying to accomplish. 😊
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Hi! Inventor drawing is quite similar to AutoCAD drawing in some ways. You can simply create a Hidden Dim Layer. Then move those dimensions that you want to hide to that layer. Lastly, make the layer invisible.
Many thanks!
