Inventor Forum
How to fill in a bended pipe?
8 REPLIES 8
Message 1 of 9
atsushi_kuno
352 Views, 8 Replies
Hi, all,
Does anybody help me with filling in a deformed pipe? I have a model below, which is converted from a mesh downloaded from GradCAD:
Actually, it is not solid. As shown in the cut section below, some areas are not circular:
As a result, 3D modelling functionalities, e.g. Loft, Sweep, or Thiucken/Offset, did not work as far as I tried. Does anybody come up with how to fill in the cavity? It is acceptable to cover the holes on the models and re-drill them later.
Thanks in advance!
8 REPLIES 8
Message 2 of 9
blandb
in reply to: atsushi_kuno
You could use delete face and heal, you could boundary patch all the holes and sculp. Can you Share the part?
Autodesk Certified Professional
Message 3 of 9
atsushi_kuno
Hi, @blandb,
Sure, attached is the file.
Message 4 of 9
blandb
You are wanting this to be all solid?
Message 5 of 9
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 6 of 9
blandb
see attached
Message 7 of 9
Hi, @kacper.suchomski,
Wow, I did not think that all the internal surfaces of the bended sections are selectable. Thanks a lot!
Message 8 of 9
atsushi_kuno
in reply to: blandb
Hi, @blandb,
Thanks. I could make it
Message 9 of 9
Yes, but it's worth noting that the walls are not tangential.
Kacper Suchomski
