Inventor Forum
How to export .ifc assembly and retain part information and selectability
5 REPLIES 5
EFLAamo
2633 Views, 5 Replies
Hello.
I want to export .ifc file of an assembly that retains selectability of individual components/parts as well as relevant metadata (name, mass, surface area .etc).
Each time I export the assembly, it just becomes "one" element, shrinkwrap option or no. I've also tried authoring components within the assembly to see if they retain their properties in the assembly when exported but to no avail. Any tips would be most appreciated.
Tags (2)
5 REPLIES 5
imajar
in reply to: EFLAamo
I've had the same problem.  Inventor does the same thing for exporting revit family files.  The best workaround I have found is to export the inventor assembly to dwg, then use autocad architectural to export to .ifc.  But depending on what connections you want, or what properties you want to keep, I'm not sure how good this will work for you . . .
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
EFLAamo
in reply to: imajar
Thank you for your reply, this shortcoming of Inventor is inconvenient and as for BIM goes very hindering.
imajar
Agreed.  Interoperatility with BIM (and even Revit) has been a nightmare for us over the past few years.  If I ever have to work with BIM software again for a future project, I will be thinking very seriously about switching software.
Aaron Jarrett, PE
LinkedIn
Life is Good.
ant
Hi, has this issue been resolved in 2023/2024?
James_Willo
Hi, the current structures for RVT in Inventor 2023/24 are All one element, or top level elements.
(authoring as mentioned in the first post is only for RFA which is why that doesn't make a difference.
If you are interested in improving BIM/AEC workflows, please join the beta community where we are always seeking feedback to help us to improve the interoperability.
feedback.autodesk.com
James W
Inventor UX Designer
