How to export a model whose shape is changed parametrically using VisualBasic?
i am looking for reference that can be helpful.
I am studying the design optimization.
It needs to create a model and calculates with Computer Fluid Dynamics  (CFD).
I want to automatically export the model which is changed the arbitrary value of the dimension parameters using VisualBasic.
Could you tell me some information to be helpful.
Thanks in advance.
johnsonshiue
Hi! This should be doable via iLogic or VB.Net. We have quite a few iLogic/VB experts on the forum.
Many thanks!
Software Test Engineer
Thank you for your reply.
I would like to try
johnsonshiue
Hi! The quickest way to obtain an answer is to share an example you are working on. There should be specific Inventor API or iLogic code facilitating file export and changing parameters.
Many thanks!
