- Mute
- Permalink
- Report
Our company, which sells office furniture, wants to offer an elliptical shape table. My project is to model and draw the table top. The modeling part is easy. I just used the elliptical tool to create the sketch then extruded it to create the 3D shape.
Next I started a new drawing, placed a top view and began to annotate it and there is my problem. The general dimension tool will not select anything other than the outside shape. I need at a minimum the radius of the major & minor axis. See screenshot below.
Another post suggested use Retrieve sketch dimension, however in my Inventor (2021) I can't seem to find that option. For example, in the Edit View, under Display Options, there is no such command. Under the Recovery Options tab, there is an All Model Dimensions command that is grayed out.
So, I am at a loss as how to dimension a simple thing as an ellipse. I've spent quite some time searching this forum but haven't found anything to help so my last resort is to post here. Surely someone has needed to make a drawing of some ellipse shaped object and run into the same issue.
Thanks for your help,
Steve
